ok i have a 1992 honda dx and i was ondering if i could swap the d15b7 engine out for the b18b1.. ithink it will ft but i dk if the b18 will bolt onto the d15 tranny... could someone help me out?
the B18b is a bolt on. Easy swap. You will also need a obd1 ecu in order for the motor to run properly.
and NO a D SERIES tranny will not bolt on to your b series motor.
Your question has been answered many times. Do a search before you post.
any b series will fit but a b20 prelude but get a hydrolic b series you could get a cable one if you like but you will have to get a conversion kit for the tranny
ooo k thanks that helps.. but do u know a website i could go look at engines and trannys.. bc i cant seem to find the tranny i found the engine for $650 Plus s/h but the tranny is nowhere to be found
