Wrong.Your going to have to convert to obd1 also in order to actually have VTEC.Just go to Rywire - Online Store and grab up some harnesses.Your also going to need a 4 wire o2 sensor,the obd1 ecu(p28) and a cable tranny.The Z6 tranny is hydro so if it comes with the tranny just sell it and buy a crx si tranny because that HF tranny sucks bad.You arent going to be going anywhere fast with that thing.Your also going to have to swap out the driver side mount with the one from your HF motor.SO convert to OBD1 and Get a Si tranny.just drop it in and wire up the vtec
yup i think it might be a lack of using the search featureseem to get ALOT of these same questions on here
You can choose to run a PM6 and activate VTEC off an RPM switch. Maybe your motor will blow up like my friend's because the PM6 doesn't have the correct fuel and timing maps for VTEC. He didn't want to spend the $400 on the OBDI conversion so now he has to buy a new engine. The choice is yours.
