help i want a zc in my dx ef and make it obd1
dok
ok guys i have a really low buget and want a sohc zc in my ef but the dam car is a dual port and the engine is a mulit port and to top shit of i want to turbo it and the dyno around me will only tune it if its it a obd1 """""" please help""""""""""
wow 600 posts and you post THAT. lemme guess, english isn't your first language? =)
You can easily make a DOHC ZC OBD1.
Rywire.com carries EVERYTHING you need.
Wiring conversion, OBD1 distributor, OBD1 chipped ECU etc... Not sure what else to tell ya except buy the engine LOL
dam and i see you are holding your dick at 4 in the morning a lol!!!!!!!! i just wanted to know how to make my dual port into a muti port and make it a obd1 by soildering the obd1 pulgs and running wires to the engine bay
Search dpfi to mpfi into this search engine and on Honda-Tech and you will be enlightened with all the information you want.
as far as the obd1 thing goes u can either spend all day converting eack wire yourself or get the conversion harness. you will also need a obd 1 ecu
