full integra brake conversion to EF civic
95db7
a buddy of mine is swapping an ITR motor/trans into his 91 civic hatch. now i realize the brakes wont hold back that power. is it possible to swap the front knuckles w/ calipers and rotors, and the rear trailing arms and brakes from a corresponding year integra? any help would be greatly apreciated.
tell ur friend to get everything off of a 90-91 civic ex(front stuff) cuz they have bigger disc brakes and actually u can get the rear disc brakes off of it too but here is what ya need
90-93 Integra Rear Trailing Arms (with everything attached Rotor, Caliper, E-brake Cables...)
or
90-91 CRX Rear Trailing Arms (with same...)
You can use either trailing arm but for CRX you need CRX e-brake cables and for Civic you need Integra e-brake cables (might as well get whole CRX trailing arm + cables for CRX, and whole Integra trailing arm + cables for Civic)
90-93 Integra "4040" Brake Proportioning Valve (Prop Valve), HIGHLY RECOMMENDED!!!
New Rotors or resurface old ones (I used new Brembo Blanks)
Remain. Calipers (if your old ones are in bad condition)
Stainless Steel Braided Brake Lines (recommended... I used Good ridges)
New Brake Fluid (I used Castrol GTLMA DOT4)
Brake Pads (I use OEM Honda/Nissin pads)
that is what i thought i appreciate your advice
No problem I am happy to help thats what this sites for even though some people who "TRY" and give advice dont realize that dont let certain people here bring you down because honestly some will.
I have had experience in that department.You should look up me in the members lounge I posted there and just got a bunch of static the post is called "new to honda swap and I have some questions" I am not sure if thats the whole exact title but the new to hondaswap is.
Once again you are welcome and if you have anymore questions feel free to IM me or email me because I get online and look stuff up and save pages or copy them to my comp
