'89 ZC axle question... help needed!
90SiZC
I need a new axle for the drivers side on my '90 Si with '89 ZC.
The 1990 Integra 5 speed axle would be perfect.... except on the trans end the splines are only cut for 1/2 the distance on the stub. I tried to fit one of those.. no go.
I need an axle splined the complete way. Is there a different axle to ask for?
Its a bummer as I needed to get the car together for work on Monday. Now I'll have to bum rides.
TIA
Jim
TIA
Jim
you need 90-93 Integra driver's side axle - it is splined full length - the passenger side 90-93 Integra axle is only splined part way
So do I use the drivers side for both axles? Or use a "set" ie drivers and passenger for replacing what I got?
TIA
Jim
Ok, picked up the drivers side axle... wrestled it in and so far so good. I owe jlicrx a definite beer or 3... :D
When I researched the swap in 2000 it was straight forward.. use '90 Teg axles. Somewhere along the way someone insisted it was 2 passenger side... and I guess I'm a dumb *ss for believing them.
Thanks again for the help!
Jim
