help with hp
shawty
so i got a h22a 1997 accord. i plan to get high performance parts, this includes: cam gears, camshafts, cylinder head gasket, stroker kit, pulleys, vavle springs, vavlve's, fuel pressure regualtor, fuel rails, oil cooler kit, spark plugs+wires, fuel pump, rods, rod bearings, forged pistons, piston ring set, head gasket, bigger cylinder sleeves(which means bigger forged pistons).. so just estimating how much HP will that make? thanks for any answers.
your hp all depends on the parts you buy. im not going to even estimate how much power you will be making until you post your setup (all of the specifics) and how you plan on tuning it. obviously you are new because you put head gasket as a mod and aem v2 intake.
give all of the brands and specifics of each item you we can give you a better idea of the power you will be making...such as cam profile, who is doing the headwork, etc
so i got a h22a 1997 accord. i plan to get high performance parts, this includes: cylinder head gasket, fuel pressure regualtor, fuel rails, oil cooler kit, rod bearings, piston ring set, head gasket
these are not performance parts, some are essential to the motor opperating. and a cylinder head gasket and head gasket are the same thing...and again not performance parts
lol right. and ya they are performance parts cuz u upgrading em to better parts. (engine internals)
not a one of those parts are going to give you any more hp. the head gasket is the only one of those parts that will have any effect on engine performance and it is so minimal its not going to be a big enought diff to even feel.
when have you ever heard ya man i just got my new honda performance bearings in today its gonna give me so much power....or man my oil cooler (waste of money) added 50hp:bash:
many ppl reccomend honda rod bearings...so there is a "performance part" to knock off of the list
btw you only have one fuel rail and one header not any more.
and aem intakes are the same as ebay ones. its all in the filter...you will learn that....most likely the hard way
i see plenty of hp adders in this
The cam gears, camshaft (get some skunk 2’s) and some JE forged pistons will make a difference I think. On the rest I think powerdriverh22 has a point. They won’t add any or a lot of horsepower. You will be building a better engine though.
