turbowizard
Dear members,
my name is michel and i live in da netherlands. I own a honda crx del sol esi from da year 1994.
I have bougt a H22a JDM 2.2liter Dohc vtec prelude engine with 220 hp with wiring harness and ecu and gear box , everthing ! complet engine block that i want to swap. And my hasport engine billets and axles are coming.
But i have al lot of Q because this is going to be my first engine swap ! i am a car mechanic so i am good with my tools and getting da engine in wont be a problem ! butt connecting some things can maybe give a problem ! so i want to know if there is someone thats has done it , or knows about it !
a few Q are :
hasport motorsports also has a wiringharness , do i also need to order that ? is that a harness so i can connect my gauges en speedometer ?
how is the gear / shift linkage ? do i need a prelude linkage or can a put the del sol linkage on da prelude gear box ?
Is the fuel rail or fuel line da same ? can i put the fuel line of my del sol on the fuel rail of the prelude engine ?
I have got a engine harness with my prelude engine and a ecu , butt if i ve got that and i connect my fuel line and my starter and i give the ecu his volt , shouldnt it start and drive ??? the gauge s dont wont than of course butt the engine should run right ?
Do i have to change my powersteering line to da prelude pump or does the del sol line fit in to da prelude pump ?
this is it for now !! Anwers are welcome and if you have any others tips of suggestions let me know ! you can also mail me @ michelbeekman@hotmail.com
THNX , greetz michel beekman, Turbowizard Developments
a few Q are :
