where is the fill plug?
i dont have the factory one, and my chilton doesnt say, and i have no money. so that is one reason why this forum exists... jerk.
they're pretty easy to find, if you get under & look around ... near/above the drain plug/nut; it's a big nut on the side on the passenger side
I found out my ex-mechanic filled mine full with motor oil ... bad. IMO only use honda trans oil
motor oil isn't that bad. it's pretty common for hondas.
Honestly that's what I thought too, get_nick. Even with my torqueless wonder .. I noticed shifter got very 'notchy' & then the bearings started makin noises it never made b4.
my nissan is like that. if i don't use royal purple, it gets that way to. I have had 6 or 7 hondas, and a lot of the time they are notchy. for some reason they don't like to go into reverse when it's cold either.
i did not mean to sound like a jerk, if that was applied to me heres a pic!!
It's also pretty easy to fill from the VSS hole...
D-Series 5 speeds take 1.9 qts
B-Series 5 speeds take 2.1 qts
