ls/vtechatch91
ok i have a set of b16 pistons and im wanna put them in my ls/vtec.. i also have a b16 head..... will i have enough valve clearance to use them? and what wrist pin would i use???
yes if the pistons AND rods are b16 you can. use the set of wrist pins for the b16.
yeah sorry about that. had the rest of the info right tho. thanks for the correction.I like your sig dude... you should get to wiping...
Like Calesta said, use the LS rods especially if you're using an LS crank.
