How To Change a Head Gasket
Heres a step-by-step walk-through of how to change a Head Gasket on your Honda's D-series motor. And btw, sorry for some of the blurry pics... I'm not a photographer :p
1. Start unplugging wires and hoses. Everything attached to the head from the car's body or the block MUST be disconnected.
attachment.php
attachment.php
2. Unbolt your header. I had to pull out my A/C fan to get it to clear the studs on the block.
attachment.php
3. IMPORTANT STEP! Set your motor to TDC (Top Dead Center), where the #1 cyl. is on the Intake stroke. Post if this confuses you.
attachment.php
4. Remove the timing belt. I just slide mine off. Remember NOT to turn the motor OR the Cam-gear after this step, unless you like head-aches.
attachment.php
5. Unbolt your head bolts in sequence. Make sure you have a manual in front of you, and unbolt in 1/4-turn increments until you can looses them by hand. Your Manual tells you all of this. GET ONE.
attachment.php
6. Keep track of what bolts go into what hole. I used stickey notes.
attachment.php
7. Head bolts removed.
attachment.php
8. Head removal. This is easier with two people. I did it by myself. I'm a framer and have a strong back, and my back still didn't like me after this.
Notes: Just make sure you don't force it. take your time. double and triple check for coolant lines. make sure the PCV valve hose is pushed out of the IM.
attachment.php
attachment.php
attachment.php
I thought it was kinda funny...
And the engine after the pull:
attachment.php
9. This is where I grabbed a water, wiped down all the oil on the car/floor/pants/desk, then just looked over my pistons.
Notes: Just take a Shop Vac and stick it on the pistons, just to make sure theres no grease/dirt/oil on them.
attachment.php
attachment.php
10. Moving onto the head, after draining the oil on/in it (by just turning it upside down over an oil pan), I took off the TB and IACV to clean them. My IACV is going out, so I figured I'd help it out a bit by cleaning the screen on it. it can't hurt. The TB I just took off for kicks and to clean it out/check out what the inside of my IM looks like (yikes! ;) )
attachment.php
attachment.php
11. Then I checked out my valves. just looking them over and cleaning them up with a shop towel.
Notes: Just take care when you flip up the head/IM, as there are a couple sensors and plugs that you could break in doing this. just a friendly reminder.
attachment.php
12. This is where I started cleaning up everything. Degreaser, followed by a toothbrush scrub, then a wipe-down with a clean Paper Towel worked Awsome for me.
attachment.php
attachment.php
attachment.php
Installation
13. Important! CLEAN the block's deck to make sure theres no dirt or grease where the new HG will sit. Then go ahead and set the new HG down and line it up.
attachment.php
After numerous failed attempts to get everything to line up, I devised a way to keep the HG in place, as well as a way to guide the Head right down on to the block- PENCILS!. Yep. They worked great!
Notes: Make sure you feel the metal dowels set into place from the Head to the Block. I believe there actually oil passages, but dowels might be more easily understood.
Also, if you desire, now is a good time to go ahead and set that Clutch cable behind/under the IM, just to give you that clean, 'wired tucked' look, if your into that sort of thing.
attachment.php
14. Soak the bolts in regular 'ol motor oil for a few seconds before screwing them down.
Notes: As you put them in, go ahead and take your rachet/socket/extention and tighten them only until SNUG, then move on to the next one.
attachment.php
15. Begin your torque'ing sequence. Remember to torque the bolts in two stages, as noted in your Manual. In my case(and most D-series cases), you torque them all to 22ft-lbs, then follow that up with 53ft-lbs. Just make SURE to follow the torqueing sequence so-as to not warp the head.
attachment.php
16. Start connecting coolant lines, wiring harness connections, and then re-install the timing belt etc.
Then your done!
Hopefully this'll help someone out there looking to try this out by themselves.
Mods & Admins, your more than welcome to move this thread into any 'restricted forums', that normal members can't post in, if you think it'll help out the site.
Comments Welcome!!!
-Andrew
TurboMirage said:
ive never heard of putting the head studs in oil...
damn newbs
those arent studs, they be headbolts...
lol...
you didnt bother getting the head milled?
you didnt cover checking the head for levelness?
didnt you just buy this engien from HMO? and it already had a blown headgasket?
fucking awesome write up. im doing a headgasket/head swap on a DA...
Yea I also wondered why there was no straight edge check for warp.. but the write up is awesome.
I didn't even think about taking a level to it.
Nope, I didn't get this from HMO. Guess your thinking of someone else.
I'll be picking up anoher d16x6 with 60k soon, so it'll be going into my rex.
Thats also why I didn't spend the money on getting it milled- PLUS I'm already running PM3 pistons which I believe it was you that told me they "Actually come out of the block", plus with the Y8 Gasket, I'm @ about 12.17:1 compression, so milling it would NOT be a very wise idea...
Thanks for the props and reply's guys. Hopefully it'll help someone out.
-Andrew
-Andrew
I dont know shit about D series, so it wasnt me who told you the PM3 pistons will come out of the block. I think that might've been Blanco.
Nice writeup. A B-series hg job has quite a few more steps involved. Just a FYI, isopropyl alcohol works really well to clean/prep the mating surfaces, as it leaves no oily residue as some degreasers can. My .02
im pretty sure honda recommends to replace your head bolts after uninstalling them.. but my lack of memory could fail me. I would of decked the head also. Sweet write-up, lots of good pics
Honda DOES tell you to replace the bolts when you remove them, but many people reuse them without a problem.
I (among others) told you that the PM3s would stick out of the block, but that's going by the 'D series calculator' and so is not necessarily 100% correct. If you're running the PM3s in there right now, I just might have to try it myself!
First time I pulled a head I tried to reuse the head bolts and snapped one before it reached torque. :( I had to hire some guy to come out and get what was left of the bolt out of the block.
nice write up Andrew! I'm assuming this was before you found out the z6 head was warped.
Hmm... I never had a problem with them. Of course, ARP studs all the way for me now :)
head gasket
:(Hello everyone! Glad to be a member.
I am changing the head gasket on my 94 Honda civic. How do I set the motor to top dead center?
An easy way to do it is to
1. take out the #1 cyl. spark plug(furthest away from Distributor)
2. Take off the valve cover so you can watch the springs. stick a long screwdriver or something into the #1 cyl spark plug hole.
3. spin the motor over by hand(17mm socket and a few extentions on the crank pully) counter-clockwise
4. watch the intake valves. wait until you are on the intake stroke of the #1 cylinder, and then start watching the screwdriver. spin the motor slowly until you see the screwdriver reach it's peak and start to go back down. work it until it's as close to the top as possible.
Thats it.
-Andrew
