93delsolsi
LS-Vtec Turbo Swap 3500
2001 B16 head With a 99 Ls Block. Engine also have AEM fuel Rail, FPR/FPG,450RC Injectors,FMU. The turbo set up is a Gredy blow off valve, Turbonetics Waste Gate, Greddy t3 turbo. Currently runing on 11 PSI. Safely. Tunning is With a P28 And a Vtec controler. The Tranny is a 98 GSR Exdey flywheel And stage 6 Clutch. Swap comes with Shift linkege motor Mounts Full Turbo Kit Axles. And what you see in the pics. Plus ECU and Vtec Control Asking 3500 OBO
B16 Block With Crank 250
Crane cams Ingition box 20
Two 10ich Bazzoka Subs 1800 Watts Each 250 firm
EClipse Touch Screen NAvigation Dvd AVN-5435 $500 Firm Only thing missing is remote and Gps Antena. But Can find For 20 dollar online.
Gsr Cluster With ORiGINAL 45685 Miles With the pic tail if you want to put it in a civic I will trow in a CD that give complete deatils and Pin out Graph
JDM Hatch Cluster 106000 Miles 160
Hatch Ex Cluster With 100544 But has a crack in the glas and you can use your old one. 100
