b16sir2 swap into a 1995 civic ex
jdm anthony
hello, i have a question for this swap. very soon i will be getting my civic and im planing on getting the b16 built for boost, (sleeved pistons rods studs valves crankshaft everything..) and i just had a basic question:
what all is needed to get the b16 to work?
axles- where can you get high hp axles from also?
b series motor mounts
shift linkage
does it need throtle cables? or anything else for the swap?
thanks, anthony
you will have to get a new throtle cable you can use the 99-00 civic si throtle cable, you can use a 94-00 integra shift linkage. i did the same swap
shift linkage
thanks, anthony
The question somewhat depends on the generation of b16 you're swapping into the civic.
You have an Ex, so you can use your rubber mounts, you'll need integra mount brackets though.
Use OEM axles, otherwise-go Hasport.
You can use the stock D-Series throttle cable, you just need to modify the bracket it sits on.
Without knowing the year of your b16 (obd specifically) it's hard to say what wiring will be needed, if any.
any more help?
also, does anyone know what obd a 95 civic is? any more info and help will be greatly apprecated :)
also how much HP can stock motor mounts and stock axles handle?
the b16 sir2 obd1 i believe it is.
Yes, but sometimes people confuse B16 sir II with b16a2 and the brackets are different and the obd is different. If you have the SiR II, it's a direct bolt in. (With B series shiftlinkage and B series Axles)
any more help?
Yes, 95 is obd1.
You'll be fine with stock motor mounts and axles if you plan to keep it stock. I'd look into upgrading mounts after 160-180whp,and axles after 250whp.
ok thanks this helped
and the motor i plan on ordering is the jdm b16 sir2
is hmotorsonline.com a good website? ive only heard positives from people who've bought from there.
And that's all you will hear, they have built a great reputation for themselves.
You can't go wrong.
