misc b series parts including block and crank
SoSlo
b series garage sale
UPDATED
JDM B16A short block odb0(dissasembled-cleaned-reassembled)_$150
JDM B16A short block obd1 (complete ready for a head)________$150
b18a1 head with all valvetrain______________________________$35
jdm b18c crank (need to be polished has 1 spun rod bearing)_____$75
b series oil pump(used)____________________________________$15
ls water pump(used)_______________________________________$10
ls timing belt(used)________________________________________$10
b series oil pickup_________________________________________$15
b series coolant tube with thermostat housing(used)_____________$20
b series water pump(used) _________________________________$10
b series idler pulley(used)___________________________________$5
b16 tranny brace_________________________________________$5
obd2 crank angle sensor___________________________________$15
obd 2 timingbelt crank pulley(chipped)________________________$5
obd 1 timingbelt crank pulley_______________________________$15
vx (13/16) brake master cylinder____________________________$5
obd 1 gsr distributer_______________________________________$75
gsr crank pulley___________________________________________$30
gsr flywheel______________________________________________$10
4 gsr pistons on rods______________________________________$35
4 b16 rods(rods scratched but usable)________________________$10
3 usdm gsr pistons with wrist pins____________________________$10
2 jdm gsr pistons with wrist pins______________________________$5
blue eg steering wheel______________________________________$10
full srs wiring harness with sensors and steering columb slide and srs ecu__$25
drive side eg manual mirror___________________________________$5
everything is OBO
i am paypal certified
hit me up at smmccurdy@hotmail.com
does the dizzy work? i need the gsr dizzy, gsr flywheel, and gsr pully. how much 4 every thing? with shipping to 16127. thanks
