how do you relocate the battery in a 91 teg rs
blazeit007
how do you relocate the battery in a 91 teg rs not to the trunk but to the back of engine
If you're gonna take the time to relocate the battery, I would say just go all the way to the trunk, makes better sense to have it back there anyway for weight distribution and such.
I don't think that I have seen anyone jsut move the battery around the engine compartment. Bescides, I don't think there is any room behind the engine for a battery, hence why it is where it is.
You can't. There isn't enough room in a g2. If anything, buy an NRG cell, and relocate it to the side of the frame rail just below the stock location.
im moving it to the back will a 130 amp alternator handle 2 batteries
its not about how many amps the alternator puts out to power the batteries, batteries are storage units, its about how much you are drawing off the batteries that the alternator has to replace. Usually if you have 2 batts a regular alternator will keep them charged, I would buy a power cap instead of another battery (assuming its for your system)
i have a 6 farrad cap and 1 optima battery , im runnin 3 amps hi mids lows but still want to race . im runnin aem cams aem air intake,msd cap and booster,aem pulleys, gettin ready for single shot of NOS
you want to race yet you weigh your car down with stereo equipment? Doesn't make sense to me. You should be fine with what you have.
you still should be fine with what you have, if you are worried about it buy another cap, possibly another battery, but you def don't need an alternatoror much over 120amps, unless you are pushing some serious wattage (over 6000 without proper capacitors)
use a measuring tape, nobody is going to have trunk dimensions conveniently for you. If it's custom, just take your car to the shop and have them fit it perfectly.
