did the search
kaoskustoms
If i am not wrong arent the 1990 and the 1991 acura integras obd0?
and the 1992-1993 integras obd1?
if so it would seem to be that the 92-93 tegs would be the best to buy for a da chassis.
any links/info would be great! as far as what the diff is between them
now you confused me man your first one says obd0 then your 2nd one says obd2
No it doesn't, all 92-93 Integras are OBD1 from the factory, all 90-91 Integras are OBD0 from the factory.
Exactly. Don't post info if you truly don't know. The B18A was OBD0 and OBD1. The B18B was OBD1 and OBD2. What engine it was doesn't matter. And it doesn't take much to run a B18A with an OBD2 ecu and a B18B with a OBD0 ecu. IDK why you would want to, but still, it isn't all that hard.
