Wiring questions...
George777
^^ Likes Bewbies
I've got 2 Audiobahn subs and a ported box...I ordered my amp so I can install everything into the car, but I need to wire the subs and install them into the box.
Is it better to wire them as parallel, or as a series? And should I wire it as 2 ohm or 4? Also, should I run it as 1 channel, or 2?
From personal experince (I do custom car audio installs) audiobahn's subs are put together rather cheap, normally all subs I install I would drop to a 2ohm load or 1ohm load and run on 1 channel, but I don't want you to go blowing your subs so to be safe, wire them parallel off of 2 channels
before you wire it you need to know what the amp is stable to ie: 2 ohm 1 ohm etc. get the info and let us know.
