J jaylo New Member Jan 15, 2007 #1 will a transmission from a d16z6 work with a d15b7 engine for a 92 civic dx hatchback.
J jaylo New Member Jan 15, 2007 #3 will I have to change anything out beside the tranny such as pressure plates or flywheels or will it bolt right up.
JDMGen2 Junior Member Jan 15, 2007 #5 Any D Series trans will bolt to any D series block. Same with B series. H and F are also interchangable.
bitchasscracker Banned Jan 15, 2007 #6 JDMGen2 said: Any D Series trans will bolt to any D series block. Same with B series. H and F are also interchangable. Click to expand... not true
turbo sol I need some ligaments!!! Jan 15, 2007 #7 yes it is if you're talking JDM to JDM but it is true that some won't bolt up if they are USDM and JDM ...they won't mix.
bitchasscracker Banned Jan 15, 2007 #8 turbo sol said: yes it is if you're talking JDM to JDM but it is true that some won't bolt up if they are USDM and JDM ...they won't mix. Click to expand... you are so dumb ok a 91 prelude motor (b20) and a 91 integra tranny (B18A) ????
turbo sol I need some ligaments!!! Jan 15, 2007 #9 i'm not too savvy on b series shit, i'm a d series guy...
bitchasscracker Banned Jan 15, 2007 #12 your a retard i told you in the other post i have the set up its 6000-6200
turbo sol I need some ligaments!!! Jan 15, 2007 #13 what you say is not golden kid...it's ok to be wrong sometimes...
bitchasscracker Banned Jan 15, 2007 #14 turbo sol said: what you say is not golden kid...it's ok to be wrong sometimes... Click to expand... SC-6152E look at the specs yourself retard i guess your right a turbo with a hp rating of 630 hp is small
turbo sol I need some ligaments!!! Jan 15, 2007 #15 i didn't say it was small, i said it's not that big, which it isn't..
bitchasscracker Banned Jan 15, 2007 #16 turbo sol said: i didn't say it was small, i said it's not that big, which it isn't.. Click to expand... your just a retard
