Recently i noticed, on my 96 civic, that there is a whine comming from the timing belt area, but only after i rev the engine or when the RPMs drop after reving
is this normal, or is my timing belt or something else going?
usually when you hear a whining sound it is the tranny but it could be something different in your case. have you messed with anythign on that side of the motor recently? any of the belts too tight?
Take a bar of soap (yes regular hand soap) and hold it to both outside edges of the belt while its spinning just enough to evenly cover the edges...........be carefull.
