crx injectors wont spary
efnastytime
i go ta crx si i just put a b16a in it the fuel rail is gettign gas but the injectors wont spary at all i took the rail off and turned the key and fuel pump comes on and fpr gauage reads 44psi but the injectors dont spary can anyone help me out
Check to see if you have power to the injectors with a testlight.
And check all your wires to see if there hooked up or crossed.
I guarentee your not getting power to the injectors
Where they working before with no probs? What kind of injectors are you using with the swap?
It wouldnt matter if it worked before or not, because when you swap you change that out.
When you say you "turned the key", did you turn it all the way to attempt to start it?
If you just turn the key to 'ACC' it will not spray the injectors.
The fuel pump, however, will prime the system and pull it up to full pressure when you hit the 'ACC' mark, but injectors won't do anything.
ok my crx has the obd0 to obd1 ecu jumper harness wat do i need to do b/c i got obd0 injectors could this be the problem and also i got a resistor box any help from anyone???
ok injecors are not gettign no power but the ristor box has one plug that has power how can i fix this??
Are you saying one side of the resistor box has power and the output to the injectors doesn't? Get a new box.
Hmm...
Have you done anything to the harness? Any wiring, extending, etc?
It's the stock harness right?
