So it is true!!!!
I guess the pumped worked so he no longer needs to compensate, hence the reason he's selling the car. I still don't understand how those things work.
silly kids...
Penis pump
A penis pump is a cylinder that is fitted over the penis, with a manual or motorized pump to create suction. As the apparatus creates a vacuum around the penis, blood is drawn into the penis causing it to become engorged. The higher the vacuum, the higher the blood-pressure becomes within the penis; excessive pressure causes vascular damage rather than a harder penis.
Pumping must be done very carefully to avoid injury: manufacturers' instructions should be followed. Manual pumps often recommend a gentle pump followed by a pause, then repeated. Over-enthusiastic pumping can burst blood vessels and form blisters. In some cases the testicles can be unexpectedly pulled into the cylinder and cause severe pain and injury. It is also believed that the rim of the cylinder can cut into the skin and over time cause damage to the ligaments surrounding the penis. These dangers are easily avoided by following instructions. Impatiently pumping without reading explanatory material can produce too much suction (anything over 10 mm Hg) and cause permanent injury. Attempts at using vacuum cleaner units for this purpose have resulted in severe injury as the machine produces far too much suction. If the base unit is used without a hose there is also the danger of coming into contact with the rapidly-rotating fan.
Penis pumps are also used for masturbation. In August 2006, Oklahoma district court judge Donald Thompson was sentenced to four years in prison for repeatedly having masturbated with a penis pump while presiding over court cases.[4]
Penis pumps, usually described in this context as vacuum pumps, have use in conventional treatment of impotence. The pump itself is essentially as described above, although often made to higher standards of quality with a much higher price, and arrangements for distribution by suppliers of medical equipment. One or more flexible compression rings are fitted on the open end of the cylinder, then an erection is created by pumping. The rings are pushed by hand onto the base of the erect penis before releasing the vacuum. This enables the erection to be held even in the presence of problems of the vascular or nervous system which would otherwise lead to immediate loss of erection. In the best circumstances erections can be maintained for a considerable time, but manufacturers' literature recommends that rings should be removed after not more than 30 minutes for safety. Having rough sex can also result in the bursting of a blood vessal
well I never had the need for the use of one to look into them.
after you posted i pulled that from wikipedia. but you have never been to a sex shop before? i've never used one either, but i have looked at the box and read it before. it just looks like it would hurt too much.
That is some funny stuff right there.
Yea I have but I've never really paid attention to stuff like that, usually the dvd section, the board games, and body toppings section.
Thats great. This thread and the Mustang Pedafile really brightened up my morning :)
That Testarossa was selling for HALF The fucking value. DAMMIT where am I when shit like this comes up ?!
little italian dick or no, a testarossa sub90k !
