No spark need help...
REDMAC
Trick or treat
Ok I've searched through like 10 pages and no help with lack of spark issues.
Car just died and now wouldn't start.
94 Del Sol SI with stock D16 vtec.
Fuses all look good. replace cap and rotor. checked and replaced ingition coil. Engine turns over but just will not start.
What am I missing here.
This is my only transportation and need running by Monday. Any ideals would be of great help.
yea the are pricey see if a friend has one you can try to make sure thats it before you drop the money
My Brothers has one but I think that its a obd0. Not sure since it was bought with a different engine and dizzy mounts up differently.
His is a D15 non-Vtec mine is D16 with VTEC. Should that make any diff???
I may have found one locally for a decent price just need to see if he still has it.
With my luck he will have but will not solve my problem...
AARRRGGGGGGG!!!!!!
you need a vtec dizzy,, i also bough one from advance auto, here in alabama if it dont fix the problem they will give you your money back
ok changing the Dizzy was no help. I checked for power going to the dizzy and getting 12v to dizzy but not getting any spark
Again...
I've replaced dizzy, ingition coil, cap and rotor.
getting 12v to dizzy fuses are good, check for spark nothing. Doesn't make any sense..
Any suggestions???????????
I have thought of the main relay also but its location is unknow to me.
I tried to find in manual (getting no love). Do you know where is is located I have another Sol here I can pull relays and such from minus engine parts and ECU (its an automatic).
well on a crx its on the driver side, and on a 99-00 si its on the passenger side but thats about all i know lol, ive never had one go out on my del sol
umm shot in the dark, check your engine ground, the one that goes to your cylinder head from the radiator support, if it is broken or all frayed, replace it.
as far as the relay, it is located mounted near the door jamb, drivers side, under dash, near the fuse box.
41938131
