teach me about linux
seriously, im interested, but im a little hesitant to make the switch since i cant fluently read/write code. and dont know much about linux to begin with. only linux ive ever played around with was knoppix when i had to backup data when windows wouldnt load, and even then i couldnt get it to do much other then copying the files. plus the whole thing with many things not being supported from what i read/hear.
how good with code do you actually have to be to run a linux setup?
wine is a package included in a lot of distros of linux. you can always install it later if its not in the distro you pick up.
Kubuntu is what most people like to call the "Flavor" of linux. There are a couple kernels to choose from, but i couldnt tell you the advantages of one over the other. The reason i suggest you start with kubuntu is it seems some programs arent compatible with the gNnome window manager (which is what ubuntu uses), and if they are compatible, they are more friendly in a KDE interface (which is what Kubuntu uses).
Beryl is kinda like style xp. itll let you customize your desktop to do all sorts of cool 3d junk.
When i get situated at my new place ill have my system back to normal (only running my windows system right now). Ill see if crome will load up into wine. Who knows, lsvtec might have already done it.
so how do you access the previously installed programs with wine? do you have to mount the partition with windows and then run the .exe?
