got new cams today
comp cams a new one for the list
part number 57302I
intake
pri 10.3 sec 9.5 vtec 12.6
pri .404 sec .374 vtec .493
pri 260 sec 260 vtec 290
part number 57303X
exhaust
pri 10.0 sec 9.0 vtec 12.5
pri .395 sec .355 vtec .470
pri 264 sec 264 vtec 296
this is a new one for the list
these will be going in a 13.5:1 crvtec with itbs and a good head job what you think
if you already have them the all good but you might be better off with some skunk pro'3s with that compression, even pro'2 would be better.
the comp cams are good tho
are you going to auto x the car or drag it?
i'm assuming you got new valve springs, valves and retainers.
yes and they are good to .600 lift and 11k rpm they should be fun to install and also i will be spraying a 175hp to this :) and to the skunk 2 pro 3s well i didnt want them and these are bigger any ways.
this is going to be a fun do what ever car mostly drag but im geting more and more interested in auto x
bullshit. you are going to blow your motor. i don't care how good your tune is.
what will you do if he posts a video of it at the drag trip? will you say your full of shit?:D I know its almost impossible to spray that much on an already super high compression motor
BUTTTTTT
you never know. I'd like to see it make 1 pass.
ok i call BS too:p
ill be runing the VP import fuel its like 121+ octane and im tuning with an AEM i dont under stand why you have to be so critial i have ran 225 with 12:5 on a friends car till it broke it lived a long time till it spun a rod bearing
13.5:1 on 121+ octane with 175hp shop of spray
what kind of pistons and rods and are they coated because eventually it will go kaboom unless you tear it down and rebuilded it frequently. good luck.
and those cams might need 14:5.1 + compression to bring out their full potential
