ls/vtec
4doortype-R
i have 94 integra b18b1 block c1 head and leak from head gasket ge ls-vtec kit
its leaking from the front/transmission side isnt it? mine did it too.
GE sends a B16 headgasket with their LSV kits. rule of thumb... you should use the headgasket that matches the block, so go buy a LS headgasket and bore out the front headstud holes so they will fit around the dowel pins.
i had the saame exact fucking problem.
The real problem
There is an oil journal on the vtec head that the ls block does not have. If you do not seal this hole then the engine will leak. The solution, remove the head, take it to a machine shop and have then tap the hole shut. It will be best to replace the head gasket since your is now soaked in oil. Check the golden eagle website for the proper gasket.
