**testing waters** FS LSV, b16 trans FS **testing waters**
formby
learning in progress
long story short
i dont want to spend more money on anything to make my 300-350 hp goal. and i know that my d series will make it there if i build it right.
So i'm selling the LSV with tranny as a swap
ENGINE IS INTACT WITH TRANNY ATTACHED
parts list
this engine was run in an OBD0 configuration
[2k miles on engine since rebuild]
81.5mm stock block
ARP rod bolts, Head studs
oem HG
oem lightened flywheel
KMS block guard
2000 SI head
oem IM/TB
Si int cam
GSR exh cam [ i have the SI int cam]
OBX cam gears [6bolt] they work great
OBD0 oem injectors cleaned by witchhunter.com
STR cam plug
ITR oem oil cooler
GSR oil/water pumps
FOCUZ header
exedy 3puck sprung clutch & pressure plate
CABLE B16 tranny no grinds [used syncromesh fluid]
90-93 TEG axles with half shaft
OBD0 starter and alternator included
THIS ENGINE DOES NOT HAVE:
WIRING HARNES, O2 SENSORS, ECU, DISTRIBUTER, LINKAGE
ASKING
$2,500 + shipping
MY ZIP IS 32837
THIS ENGINE WAS BUILT BY J&Y MACHINE SHOP IN KISSIMMEE FL
I ALSO HAVE THESE ITEMS FOR SALE
if i sell the engine
ALL ARE NEW NEVER USED
UNLESS STATED
81.5mm cometic lsvtec HG $50 shipped
OEM b18c5 valvve cover gasket set $45 shipped
polished b series valve cover [no wire cover] $90 shipped
OEM oil pan gasket $14.98
1999 civic si AC/PS & T bracket. $70
moroso oil pan $143 shipped
OBD2b SI distributer $167 shipped
silicone valve guides $89 shipped
B SERIES hydro to cable mount $179 shipped
LIKE NEW
EAGLE Hbeam rods for LS B18 a/b $250 shipped
they have been resurfaced to like new
LS SHORT BLOCK $200 might need rebuild
OBD0 MSD CAP vtec/nonvtec $15
OBD0 distributer DOHC VTEC...new coil/cap, rotor $35 ea OBO
TOKIKO BLUE set $200 2k miles
H&R sport springs $99 2k miles
1990 integra complete disk brake conversion F&R $190
includes pads, rotors calipers, rear arms, brake cable
1991 non rolling crx shell NO rust, dash, plastics,harness, carpet $250
im sorry bro i read it too fast. wish you did tho. good luck with the sale
I have an odd request, the bushing for the clutch pedal. Its the peice the pedal pivots on and the mounting bolt goes through. Would you be willing to sell just that?
Bump for Formby!
I might be interested in the DA brakes...
PM sent
weird one for you
the plug on the firewall where the a/c lines normally go through on a non a/c car
would you have that??
also bump for a great seller
the pivot thing i need a pic
andrew why dont you come pick up the crx... ill give you a good price
and
the the crx had ac so it doesnt have the plugs
thanks for the bump guys and i could not be a good seller with out such great clients... thanks
C'mon man, don't tempt me!
I mainly just need to upgrade my brakes.
I wanna find a complete shell or something... I wanna at least have a dash! :D
LMK what you can do for me about those Brakes. I'll come down and pick 'em up if you want.
