crxricer88
whats the difference between supercharging and turbocharging what's best for a crx?
this has been asked a million times. yes it can be done. no, it's not worth it. any turbo's will work it will just cost 1 gazillion dollars.just a question, can a twin turbo be put on any of the honda engines? if they can which ones?
if you have to ask, you won't be able to do it yourself. you will have to fabricate everything and make custom manifolds and fittings. it really isn't worth it, thats why nobody does it.could you make your own twin turbo by going to the junkyard, and get a twin turbo and just hook it up to your engine with the blow off valve, manifold, etc?
no problem man. it just isn't reasonable to do. but yes, it has been done. single is the way to go.its just a question that i had. i read the make your own homemade turbo and i was just wondreing if it was possible to make a twin turbo. i am still a newbie at this, all i know is that the single turbo has a lag, and a twin turbo has less of a lag and produce more hp, so i was just wondering thanks for the responses
