burning oil!!!!
redef91
what up guys... i got a problem wit my motor....i got a 98 type r head all stock with a gsr bottom end wit wisco 11.5 comp pistions...eagle rods....when im driving on the highway at like 75-80mph the car smells like buring oil badly.....i did a comp test to it and its good all across...my boy told me its the valve seals r gone...i dunno....i go throu like half to a qt. of oil a week depend on how i drive it.....let me kno guys...
There is a good chance it could be the valve seals. How many miles are on the head?? If it has alot you should just pull it off a have a valve job done and get some new oem valve seals.
You can lose some power when your valvetrain is worn. It wont have as much compression since there will be a little leakage past the valves. But from what i have seen these high revving vtec heads go through hell and they need a valve job at 80,000 miles in my opinion to perform at peak performance.
thanx man yea i dont kno the milage prob high i bought the motor like that sooo....i diff agree with you since i bring my shit up to 8700...
engine could also be leaking oil and dripping on the header/manifold downpipe, causeing the oil smell
just a thought.
otherwise its prolly your valve seals, or at worst you didn't seat the rings properly during the break-in of the engine after you put the pistons in, and now the cylinders are oval. . . not good.
i got the motor like that soo i dunno the block was already bulit and the guy i got it from bought the head from ebay so i dunno if he brought to machine shop....i did a compression test to cylinders and no leaks but i dunno if it matters....
a compression test isn't gonna tell you everything, I recommend you do a leakdown test, or bring it somewhere where they can do a leakdown test.
Leakdown testing will tell you alot more about the condition of the engine, here is a writeup on how to do it. it's not a complete writeup, but it gives you a general idea on how to do the test.
https://hondaswap.com/general-tech-articles/how-leak-down-compression-tests-29104/
Yah, just like i said......
thanx guys ill get sumone who knows how to do it...ill post up what happens...if it pistons rings then fuck it ill put higher compression pistions like 12:1...
