vtcornercarver
Do you know if I can put a used D16Y8 vtec motor into my 94 civic DX and bolt the motor onto my original clutch/tranny? The stock motor is a D15B7 and it is shot. I plan on upgrading the clutch to a heavier aftermarket kit, but am not sure if this motor will bolt onto the trans. I understand from motorswap 101 that the motor is a bolt in replacement, and that the vtec needs to be wired. I guess I need to know what is involved in the vtec wiring. The junk yard with the motor does NOT have the ECU from the donor car that had the low mileage D16Y8 motor. ANY SUGGESTIONS WILL BE APPRECIATED.
