b16a2 in 91 civic si hatch
jason22ga
jason91si
ok i have a 1991 honda civic hatchback i just did a d16z6 vtec swap but i found what seems to be a deal on a b16a2 just wondering what else ill need to install it here is a list of what im getting for 800.00.the guy said the only things i needed were tranny,axels,shift linkage,what do you think
b16a2 engine with 62,000 miles
engine mounts.
engine harness.
sir distributor.
sir ecu.
obd2 distributor.
obd2 ecu.
dc sports header.
2000 si seats.
lowering springs.
hi performance cat.
engine mounts.
engine harness.
sir distributor.
sir ecu.
obd2 distributor.
obd2 ecu.
dc sports header.
2000 si seats.
lowering springs.
hi performance cat.
Your car is probably obd1 and i definetly recommend staying obd1. So you would need the obd1 dizzy, and alternator. You can use the injectors off the z6. Then you would need a p30 obd1 ecu, or a p28 chipped ecu with say a p30 base map. Then you would need a clutch, flywheel, shiftlinkage, and transmission. I guess if that sir ecu has is a p30 then you wont need one. Im not sure what the mounts are out off, if they are out of the si then they wont work. I believe you can use the mounts you have now, but you will need the rear bracket out of the si, and the drivers side bracket that bolts to the block with 3 14mm bolts.
