Not true, there is now a kit on the market that allows for the use of b series trannys with h and f series motors. It is being reffered to as an h2b kit. H2B Kit Contents
Here is a car on honda-tech.com that is using the kit, there was another but they ended up selling the h2b swap.
HondaMarketPlace.com: Northeast: 1992 Civic Si captiva blue h2b wire tuck jdm ctr
When you assume you make an ass out of you and me. Perhaps you should take into consideration the popularity of the h series swap and the possibility that this guy would like to do one.I am actually aware of that, but I'm assuming it's fairly expensive
Wrong again, the f20b is not an obscure motor found only in European accords. It is also the power plant in the jdm accord sir which is readily available for a decent price from any engine exporter. When you assume you make an ass out of you and me. Perhaps you should take into consideration the popularity of the h series swap and the possibility that this guy would like to do one.
