Doing a compression test. Need to know which fuse to pull.
SlushboxTeggy
It's only stupid if it doesn't work
VIP
OK so I'm finally getting around to doing a compression test after the teg (B18B) has been running shitty for a week and a half, but I have a quick question. What fuse do I pull to disable the fuel injection? The tutorial I found said 15A but that was on a B18C and my 15A fuse is labeled ECU. Is it still the same fuse? Let me know, thanks.
