Quick noob question
slow1pt7
I searched around but couldn't quite find my answer. I've got a b16a2 and just wanted to confirm that I could put a set of GSR cams in it. Also, what is a good price for a set of used ones? And what kind of performance gain could I expect out of them? Thanks!
Adam
Any dohc vtec b series cams are interchangeable. But when running anything more aggressive then a gsr cam it would be necessary to upgrade your springs and retainers. If you are going to stick with gsr cams you will definetly be ok there. They usually go anywhere from 50-150 bucks in good condition. You can expect maybe a 7 to 8 horsepower gain at the most without any tuning. Good luck.
i know.. i was just asking which ones he thought
That is why I said dohc vtec b series before!!
Yeah but I said dohc with vtec. The b20 is not equipped with vtec, unless you bolt on a vtec head.
