hi guys
Status
Not open for further replies.
aco
edit:
hy mans, i´m aco and i'm living in tenerife (spain)
I have a deep one vicic d16z2 (1991) not vtec and wanted to know if I can change him the head by a that be vtec. if is possible to do it and if I have to change the ecu of the car. the butterfly of my car is worth me? i´m verry young in this world the hibrid civic, thanks
hi there.
i think it would be easier and cheaper to just do a whole single cam vtec swap. you would use the same axles and everything, just get the new engine and ecu. then you would want to wire up the vtec.
ok ok i don't change all head. only the vtec cam... and i can use my ecu with chip? and i must modify the electrical circuit for it? thanks man
changing the cam wont work. a vtec cam wont fit, plus you still need other stuff like the vtec solenoid.
but i think the head ZC and a2 are different, and my ecu?i can use it?
you can use it, you just have to re-chip it and wire it for vtec.
find a vtec head Z6 perferably and get a ecu conversion harness with P28 ecu, Z6 dizzy with dizzy jumper harness and then from there is plug and play very simple
Status
