floridachill71
Lean and Mean
what kind of ignition is in my obII jspec gsr? breaker points? magnetic pickup? i need to know for the msd boost timing master
one of those turney around thinga ma bobs that has a metallic lead connected to the cam shaft, and then that lead hits the little metal things inside the cap that puts electricity in the wire allll the way to the plug.
you use the magnetic pick up.
how bout you read what i wrote above rather than getting offended that i hurt your feelings.
ok GOD. is it ok if i call u that? your highness? your majesty? the almighty? whatever u like lord. now if u dont mind, i have the universal msd btm / pn5462. NOW which one do i use?
AND, it will see a shop, and it will see a dyno. this is just what i have right now, and ive got to make it work for the time being. the only shop around here wants 1500 for hondata/install/and however many dyno runs. is that rape??
