goldgreen90ef
goldgeen90ef
i have a pw3 ecu running my b16 swap, and i want to chip it. i want it to only look for one 02 sensor, lower the vtec, and raise the redline. whats a good company to do this??,,,and i dont want to go obd1,thanks
does that ecu even exist? you sure you aren't mistaking it for a pr3 or a pw0?
couple more points, if you lower the vtec, you will be slower, if you raise the redline you'll blow your motor... that is if your motor is still stock.
