integra switched to obd2 in 96.. but yes, with mounts, axles and linkage.. its pretty much a straight swap.. all 92 civics were wired for vtec from the factory.. so if you're swapping a vtec motor you'll need to run a wire for the knock sensor and extend the vtec wire
