importphanatic94vx
what rpm would you launch a 1994 civic vx w/ a d16z6 swap?
yup...go to test and tunes at a local track. focus on 60' times then just coast the rest of the way down the track. you don't have to beat on your car if you are just practicing.experiment...
eh, 3k..
ouch! best regards to your clutch!
On shitty no-sidewall tires that fit on steelies, I drop at 3 cuz i'll spin em like shit, then i can't floor it either or i'll just spin em off, just 3/4's the throttle till vtec kicks then let it all hang out. On my Kuhmo's (semi-low profile), I launch at 3500 and floor it from the get-go.
I'm runnin a JDM '95 B16 swapped into an '00 EJ6 coupe. 16" Enkei RS5 rims, Kuhmo Extesa (or w/e) ASX's, cheap, decient tires. Stock clutch now, Action Clutch 2KS sittin in my workbench waitin for a Toda flywheel.
I hold the throttle to keep the rpm at 3k. I have a hondata system installed, but dont have the clutch switch hooked up yet. But then i'll be able to set a rev limit where i want to launch and when i drop the clutch it instantly removes the rev lim, for those of you that didn't know. Google 'launch control' if you have no idea what i'm talkin about. Idk how well that works yet because I havn't personally tested it, but if the Aston Martin DB6 has launch control like me, it must be good shit
