boring out a b18 block
y2kg0p317
i plan on boring out my b18a block and was wondering what is the max it could b bored without sleeving it?:D
I would not go more then .20 over on a factory block regardless of what any one says. It you are planning on running alot of boost I would recommend .10 pistons or aftermarket sleeves. If you are running all motor go .20 over for that little bit of extra power.
Typically 1mm without boost, .5mm with. You're not going to gain that much displacement by boring out the block without a sleeve job.
thanks ppls, decide to just buy a block with it done to it. worked out to be much cheaper.
Not to nit pick, but I think you mean 0.020 over and 0.010 over?
