You dont have to use ITR axles. Any b series axle that is for a manual hydro trans will work. You will need the half shaft also from the same vehicle. It will work with the hubs you have now, no modifying there.
The reason i asked is b/c i've heard the 98+ jdm
ITR uses 36mm axels and the older ITR's use 32mm ones.
