I plan on boosting somewhere near 300WHP. It would be a daily driver and I would like it to be very reliable. So therefore I do care about gas mileage.
I kinda have a setup already tell me what you guys think. Ill have to find it cause I can't name every part.
hmm im sorta in the same boat here, but im looking to make 200 whp on stock internals, somewhat of a modest goal. you are building this i assume.. since you want it very reliable?
Well here is my setup I got so far:
Port and Polished Head
Skunk2 Valve Train
ARP Head Studs
Wiseco Forged Pistons
Eagle H Beam Rods
ARP Rod Bolts
ACL Race Bearings
Stage 2 Crower Camshaft
Turbo Kit
3"Exhaust
What do you guys think of this setup, im open for suggestions. How much whp would you think is better if its going to be daily driven????
Skunk2 Valve Train
ARP Head Studs
Eagle H Beam Rods
ARP Rod Bolts
ACL Race Bearings
okay is it possible to get 30 or more mpg with 300hp and proper tuning. If I want something with good accel I would want a smaller turbo and if I want something with good speed I would want a bigger turbo correct??? How would I know what kind of turbo specs I would want????
well you could just get a big enough turbo that you could stay out of boost while daily driving around and still have some pull up top since you can rev it out a bit more with the head work. I personally think the sc61 or the smaller sc34 would be a good choice. The 34 is similar to the t3t4 suggested above.
bigger turbos are better for more horsepower. you need to know the horsepower your looking for and go with a turbo the is efficiant in the hp level and amount of boost your going to run to get to you achieved hp.
it just takes longer for a turbo to spool the bigger it is. for 300whp go with a gt28rs or a 50 trim will get you to your goals.
