i still dont no what double clutching is lol, but no lift shift is for drag racing, just once you floor the gas keep it there even while you shift lolDude, there is a good reason for double clutching. Not only does it save your driveline and tranny, but it also saves your syncros. Also, while entering a sharp turn at high speed, double clutching will provide a smoother entry instead of jerkin your car around.
And what is tha "no lift shift?"
your wrong read the link that sol postedpersonally i dont see the point in pressing the clutch twice when you could just push it hold it rev it to where you need it while you drop to your lower gear and then release the clutch. i mean correct me if im wrong
