wtb LS motor cheap/good price
grogers
looking to buy ls motor for my 1995 ex manual, id want full swap, so ecu and all that just hit me up with what you have, miles and your price...
I dont have a complet swap, but i have the complete motor w/out tranny. its a 94 ls, has 130k. motor run and was remove to install a b16a2. complete motor w/out tranny $300. also has ecu for $100, I think i might have the axels too, not sure, but will look if intrest. Also refered to my other post for more detail on this item. you could pieces together a complete swap for cheap since ls stuffs are adbundance on ebay.
:D hey i got 300 for the motor but a couple questions will it sit in my 90 teg ls i dont have the money to buy all new shit like dizzy ecu starter alt. ect so would i have to buy all that stuff or would the stuff off my a1 work
dont wanna tread jack, but a quick reply. i dont know if this will fit in your 90 teg, im sure it will, do research! as far as you buying/or reuse your items that you listed, its up to you. this motor that im selling if i remeber correctly, it came with diz, header, im, complete and everything else except the tranny. Will double check since it just sit around in the garage collecting dust.
on the block stamped 93 but as we all know, the actual vehicles are not in the market until 94' please refer to my other thread for more info
if memory served, your 95 ex is an obd1 same as this ls 93 motor and should drop in perfectly with minor mods such as motor mounts, axels, and shift likage. you could use your existing ecu and wireharness.
I have a B18A1 that came out of a 31,000 mile integra. The motor has JE 11:5:1 pistons, and eagle rods. It also has a webcam crank and has a mild port and polish, the motor has been bored .50 over and has JE rings, valves, and valve retainer springs, and multi layer head gasket. Your buying the block and head, built buy Viera auto tuning, one of the most premier acura engine builders out of Rochester, NY. Im looking to purchase a car, and it cost me $1800 to build this motor , My loss and your gain, all I am asking is $600 OBO
P.S its just the complete block and head
You can Email me at: itzstephens@yahoo.com
or aim: ItZ Stephens
