i just put in my zc and it is overheating my fan wont turn on its getting power and we tested it and it works, is it the ecu not telling it to turn on or is it the wiring . can anybody help me with this?????
could be a bad fan switch - unplug the fan switch connector from the back of the block, turn ignition switch on and connect the 2 wires in the connector together - the fan should come on - if it does, then the switch in the block is bad
