jasontyrone
I just bought a b18 with a T3/T4 turbo with a BOV and waste gate. the guy i bought the motor off of said that the turbo is set at 12 psi. i want to go down to 8 or 9 psi how do i do that?
The spring is in the wastegate. You're gonna need to educate yourself a little on how turbo systems work before you start playing around with yours.the guy i got the motor from said that all i need to do is replace a spring to a different spring to bring the psi down but, i dont know what this means?
i think you need a new turbo because if that turbo is set to 12 then you need to get a turbo that is set to 8
awww come on. why not?
