D16a6 problems!!!!
ep3moschini
I R T3H NO00Bz!
ok so I just purchased a 91 crx it had a hacked dpfi to mpfi set-up on it ran thru the whole car, got all the wires right, tossed in a fresh battery and went to turn the car over. I dont hear the fuel pump, the starter dosent even make a click, I dont knwo what to look for at this point, I dont know where to see if the ecu is getting power or the fuel pump, also where can I check the ignition for its power? I check the starter its getting juice. . . im just getting lost and pissed almost, any help will be greatly appreciated! thanks!
If you disconnected any wires go back and double check those. Check all your fuses just incase you shorted anything.
I went thru the whole car and could nto find anything, I found the main relay, but dont know how to get to it its covered mostly by the dash. . .
if I didnt state this before, Someone started this swap, I purchased the car not running.
busy tomorrow? :) i could give you a hand for a bit after work.
im going to be arround pm me for my cell number, I got a new one
so I got my first sign of life out of the car, the door ajar bee-beep beep came on after fucking with some grounds, still no cranking or fuel pump tho
Sounds like you need to fuck with some more grounds.
i say we just drop the motor this weekend replace the interior harness and engine harness with si harnesses rebuild the motor and deal with it after the motor is in cuz that harness is haaaccckkkkkeeedddd
I think thats the rout im going to go. . . ;)
replace all the groundsssss.
joe i cant make it out tonight, gotta go pick up my neice after work :(
I checked all grounds. . . decided to pull it today. . .
