You've got issues.. Should be able to rev it over 7k with no problem. I think the actual red line is 68 or 6900rpms, but a factory motor/ecu will let you run it a little over that. With a proper chip (that removes the rev limitier), you could rev it to 8500 or so. But I wouldnt reccomend it.
yes it is the same ecu that came with the motor and the tranny its a p75 ecu. i dont know i think its the oem tachometer thats in the car its not reading right. its will not rav pass 5800
Ok guys i just found out the problem after checkin out everthing i found out my gas cap was off so i pop it back on and now its koo. redline at 6300 now
