Del sol B to D swap shift linkage question.
Da1andonlyJinx
I'm getting a B-series swap from a del sol and putting it in my EG civic coupe. The question I have is, Will my shift linkage from the EG work on his del sol? I'm switching out complete swaps. I know I have to get linkage for his B16 to work in my EG, but Will my Linkage out of the EG work in his Delsol? Or do I have to get a Single cam delsol linkage for it to work? Thanks in Advance.
863-934-3657 Jonathan
Well, was doing the swap today and NO, the d-series shift linkage from my coupe does NOT fit in his del sol. And I don't know if his b-series shift linkage is gonna fit in my coupe because we didn't get that far today.
what is there thats keeping it from fitting. it should fit.
if not then get a shift linkage from a 94+ integra.
i couldve sworn that they should fit.
We didn't get to see if the delsol b-series linkage would fit in the civic coupe or not. But we now know that the civic coupe d-series linkage will NOT work in the delsol.
hit up a junkyard. get the integra linkage.
or you can order some off ebay, avid racing, hasport, etc etc etc.
yay for learning new things.
the linkage out of his del sol should work in your civic and vice-verse. no need to buy more. ,
WRONG,
del-sols are completely different as far as the shift linkage goes, everything else is the same, but linkage is totally different. You have a couple options, if you are pudding a d series in the del-sol, then you have to get linkage for a del-sol with a d, which was the majority of them, if you are trying to put a b series into the delsol, then you need 95 del-sol vtec linkage, OR hasport or similar company liinkage
Likewise the linkage that was in the del-sol will not work in your eg, yu can use integra linkage from any year 90-01 integra.
axles and everything else shoud be the same tho.
WRONG,
yep, already came to that conclusion.
