ls rods - you need to notch the bottom of your cylinders so they clear the walls and use a set of vaitara pistons and you can run up to 20 psi maybe more anyway it drops your compression down 8 to 1 i seen a few people out there who have this and are running around 20 psi on a good tune
check it out for your self
