23mm DC2 ITR sway bars
TorontoJdm
im not sure if these are 22mm or 23mm....im for sure its for integra 94-2001 and it can be use for civic 92-95 also...but i'm selling it here for 100.00 shipped...
you guys can check our stuffs in ebay and our store is eBay Store - torontojdm: Honda Acura: JDM F20B 98-2001 ACCORD SiR-T TypeR ENGINE or torontojdm
this would direct fit a integra typeR 98-2001 or jus a regular ones but it requires subframe reinforncement kit and d bracket from Acura dealership....for bought EG and DC2
i agree.. they are an awesome upgrade.. especially to the EG/EH chassis.. will be getting in touch with you soon hopefully.. do they include the endlinks, brackets , etc.. ??
yea man i compare the 12mm to 22mm and the 12mm you can literally twist it and the 22mm is just rock solid...i guess it does really transfer all the torsinal flex on both suspension....
the difference between the GSR and ITR bar are phenominal. the bars have a greater effect on the mirage chassis because it is much lighter than the EG/DC chassis.
the 14mm GSR back SUCKS. it provided a decent difference from no bar though, while i had it on. the 21mm ITR bar is much better. i can jack up one corner of the car and the whole sides comes up. its neat :)
all the braces are is two pieces of 2/5in steel on the top and the bottom of the trunk sheet metal that the d-bracket bolts pass through. there are four all together, two on each side.
i think soon though i will be running a piece of steel in between them and welding them to the floor. the bar isn't going anywhere or getting changed out... except maybe for a bigger one :)
so you have plenty and the price isnt gonna change is it?.. if i sell some shit i'll pick one up this month..
