lowered EG how big is to big on tires?
ilubmyEG
Im looking at some 195s that are 8 inchs wide(15inch Rim size) ill have a skunk2 lowering suspension is this to wide? my buddy said go 7 inchs but this is an awesome deal I could get on these rims a set of 4 with brand new tires for 250 bucks woot! let me know if these will work skunk2 said it will give me around a 2-21/4 drop will it rub or should I be okay?
i know.. i was referring to the 195 on an 8in wide rim.. that tire is too small for an 8in wide rim and would look ridiculous
That doesn't show them from the side. They'll looked super stretched across the rim.
Make sure the offset is correct for that wide of a rim, too.
hmm could there be any down effect besides look? I am going to check them out if I like how they look would it be a good purchase?
After a quick search of the forum, using the search feature, it looks like you'll want an offset around et35.
I dont know what the et35 is... basically was looking for a quick answer of whether I should buy them or not... if you want to explain what that is ill be more then happy to be educated :D
with an 8" wide rim you'd want to run 205s at the least.. but 215s would be ideal
Thanks I appreciate it now I know why my vx rims look funny cause they have a 215 on them, I dont think the rim is that wide but they just look a little odd ya know? well I have some 215s and 205s but are for a 14 inch rim not 15
